kan das hier jemand vom Dragonfly 74D ueberstzen ?
Ich mache eben eine Deutsche Beschreibung im Shop. Kann aber nicht gut Englisch
Features
1).CCPM mixing control system and collective pitch structure make perfect 3D maneuvers such as roll, inverted, and swoop flights.
2).3D aerobatic flight courses offered by professional flybar for 3D helicopter, whole metal swashplate, high rigidity steel main shaft, and high density fiberglass rotor blades.
3).The design of main frame is accurate and stable. The high quality autorotation landing system incorporated a one-way load bearing surface that effectively protects your helicopter for safer landing.
4).Belt transmission structure adopted by the tail rotor blade and adjustable tail rod holder are easy to be adjusted and stable to be run.
5).Aluminum two-section exhaust pipe enhances the engine stability.
6).40g servo is prompt in response, and enhances the helicopter stability and operation agility.
7).Professional 50 engine for helicopter, with rational gear ratio and high performance gyro GH2, offers outstanding flight courses.
.Matched with the WK-0703 LCD transmitter, it is possible to set customized parameters.
